Victor1221
Mar 08, 2025Aspirant
CM3000 Browser Issues
I am writing to report an issue with the cable connection site on Chromium-based browsers. While other functions of the site are functioning correctly, the loading time for the cable connection site ...
- Apr 24, 2025
It appears that the issue was caused by an extension, which is challenging to identify. The problem lies primarily on the development side of the extension I am using. Therefore, the issue has been resolved. Still find it ironic noone from netgear even responds to forums pretty disappointing just like the XR1000 that's been left to rust,
Victor1221
Apr 24, 2025Aspirant
Apr 24, 2025Guru - Experienced User
We find that only when major issues appear do moderators come if for help and some information. Seems like this wasn't major and was not a NG issue.
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
