Punster
Sep 11, 2025Aspirant
CM3000 Cable Modem Upload Stream Issues
I have had Cox communications to my house several times in the past month and a half. They've replaced all the cable connections both in and out of my house. I have 2 gig download 100+MBPS upload. ...
Punster
Sep 12, 2025Aspirant
According to Cox they don't do firmware downgrades and they're waiting for the fix from Netgear. They offerred one of their modems to use in the meantime.
Sep 12, 2025Guru - Experienced User
They do, just someone there may not be wanting too. Up to you, take there modem for a bit while NG and the ISPs get this worked out. NG has to fix this then sent to ISPs to have them test and certifiy on there network, if all good then, ISPs will push to modems. No idea when that will happen.
