dannoz
Jun 18, 2025Aspirant
CM3000 Comcast Business Slow Upload
Using the Comcast provided modem I get > 300 Mbps upload. Changing to the CM3000 I get 30.
I've spent hours with Comcast tech support and had multiple technicians out.
Thoughts?
Cable Diagnostic
Status: Good
Action:
Your setup looks fine. If you can't access the internet, make sure you properly activated the modem. If modem has been activated and you still can't access the internet, contact your service provider for troubleshooting help.
If you can access the internet but has other internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
CM Status: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR Level: Good
Upstream Status: Good
Upstream Power Level: Good
Current Time: Wed Jun 18 10:14:04 2025
Startup Procedure
Acquire Downstream Channel: 495000000 Hz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
IP Provisioning Mode: Honor MDD IPv6 only
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 12 495000000 Hz 4.5 44.4 0 0
2 Locked QAM256 1 429000000 Hz 5.4 45 0 0
3 Locked QAM256 2 435000000 Hz 5.4 45 0 0
4 Locked QAM256 3 441000000 Hz 5.2 44.9 0 0
5 Locked QAM256 4 447000000 Hz 5.2 44.8 0 0
6 Locked QAM256 5 453000000 Hz 5.2 44.8 0 0
7 Locked QAM256 6 459000000 Hz 5 44.7 0 0
8 Locked QAM256 7 465000000 Hz 4.9 44.6 0 0
9 Locked QAM256 8 471000000 Hz 4.8 44.5 0 0
10 Locked QAM256 9 477000000 Hz 4.8 44.5 0 0
11 Locked QAM256 10 483000000 Hz 4.6 44.4 0 0
12 Locked QAM256 11 489000000 Hz 4.6 44.4 0 0
13 Locked QAM256 13 501000000 Hz 4.5 44.3 0 0
14 Locked QAM256 14 507000000 Hz 4.4 44.3 0 0
15 Locked QAM256 15 513000000 Hz 4.2 44.1 0 0
16 Locked QAM256 16 519000000 Hz 4.1 44.1 0 0
17 Locked QAM256 17 525000000 Hz 4.2 44.1 0 0
18 Locked QAM256 18 531000000 Hz 4.3 44.2 0 0
19 Locked QAM256 19 537000000 Hz 4 44 0 0
20 Locked QAM256 20 543000000 Hz 4.1 44 0 0
21 Locked QAM256 21 549000000 Hz 4 43.9 0 0
22 Locked QAM256 22 555000000 Hz 4 43.9 0 0
23 Locked QAM256 23 561000000 Hz 4.1 43.9 0 0
24 Locked QAM256 24 567000000 Hz 4 43.9 0 0
25 Locked QAM256 25 573000000 Hz 4.1 43.9 0 0
26 Locked QAM256 26 579000000 Hz 4.1 43.8 0 0
27 Locked QAM256 27 585000000 Hz 3.9 43.7 0 0
28 Locked QAM256 28 591000000 Hz 4.1 43.8 0 0
29 Locked QAM256 29 597000000 Hz 4.1 43.8 0 0
30 Locked QAM256 30 603000000 Hz 3.9 43.7 0 0
31 Locked QAM256 31 609000000 Hz 4 43.8 0 0
32 Locked QAM256 32 615000000 Hz 3.9 43.7 0 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 18 5120 Ksym/sec 22800000 Hz 38.3 dBmV
2 Locked ATDMA 19 5120 Ksym/sec 29200000 Hz 39.3 dBmV
3 Locked ATDMA 20 5120 Ksym/sec 35600000 Hz 40.3 dBmV
4 Locked ATDMA 17 5120 Ksym/sec 16400000 Hz 37.5 dBmV
5 Not Locked Unknown 0 0 0 0.0
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 193 957000000 Hz 1.58 dBmV 41.4 dB 148 ~ 3947 6699720 5862969 0
2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
1 Locked 12 ,13 43 36200000 Hz 35.5 dBmV
Is this speed seen with a ethernet connected PC connected directly behind the CM modem? No router in between?
https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the brand and model of the host wifi router connected to the modem?- dannozAspirant
It's connected directly to a UniFi cloud gateway Max. The speed test is run on the router directly connected to the modem.
When I connect with the Comcast provided modem CBR2-T I get 1.4 Gbps down and 400 Mbps up.
When I change to the cm3000 the downstream stays the same and the upstream drops to 35 Mbps. Firmware V5.01.02.
Comcast business is now saying that the CM3000 modem only supports 35 Mbps upstream.
Sounds like you'll need to use there modem on there business line.
- KitsapMaster
For Comcast Business accounts, there is a chance the CM3000 has not been certified for connection to the Enhanced Speed Network.
Make a Technical Support post over on the Reddit Comcast_Xfinity forum and they should be able to give you an answer. https://www.reddit.com/r/Comcast_Xfinity/
