dannoz's avatar
dannoz
CM3000 Comcast Business Slow Upload
Using the Comcast provided modem I get > 300 Mbps upload.  Changing to the CM3000 I get 30.
I've spent hours with Comcast tech support and had multiple technicians out.
Thoughts?
Cable Diagnostic
Status: Good
Action:
Your setup looks fine. If you can't access the internet, make sure you properly activated the modem. If modem has been activated and you still can't access the internet, contact your service provider for troubleshooting help.
If you can access the internet but has other internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
CM Status: Good
Downstream Status: Good
    Downstream Power Level: Good
    Downstream SNR Level: Good
Upstream Status: Good
    Upstream Power Level: Good
Current Time: Wed Jun 18 10:14:04 2025
Startup Procedure
Acquire Downstream Channel: 495000000 Hz  Locked
Connectivity State:          OK       Operational
Boot State:                  OK       Operational
Security:                   Enabled   BPI+
IP Provisioning Mode:       Honor MDD   IPv6 only
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID  Frequency     Power    SNR   Correctables Uncorrectables
      1     Locked     QAM256     12     495000000 Hz     4.5     44.4     0     0
      2     Locked     QAM256      1     429000000 Hz     5.4     45     0     0
      3     Locked     QAM256      2     435000000 Hz     5.4     45     0     0
      4     Locked     QAM256      3     441000000 Hz     5.2     44.9     0     0
      5     Locked     QAM256      4     447000000 Hz     5.2     44.8     0     0
      6     Locked     QAM256      5     453000000 Hz     5.2     44.8     0     0
      7     Locked     QAM256      6     459000000 Hz     5     44.7     0     0
      8     Locked     QAM256      7     465000000 Hz     4.9     44.6     0     0
      9     Locked     QAM256      8     471000000 Hz     4.8     44.5     0     0
     10     Locked     QAM256      9     477000000 Hz     4.8     44.5     0     0
     11     Locked     QAM256     10     483000000 Hz     4.6     44.4     0     0
     12     Locked     QAM256     11     489000000 Hz     4.6     44.4     0     0
     13     Locked     QAM256     13     501000000 Hz     4.5     44.3     0     0
     14     Locked     QAM256     14     507000000 Hz     4.4     44.3     0     0
     15     Locked     QAM256     15     513000000 Hz     4.2     44.1     0     0
     16     Locked     QAM256     16     519000000 Hz     4.1     44.1     0     0
     17     Locked     QAM256     17     525000000 Hz     4.2     44.1     0     0
     18     Locked     QAM256     18     531000000 Hz     4.3     44.2     0     0
     19     Locked     QAM256     19     537000000 Hz     4     44     0     0
     20     Locked     QAM256     20     543000000 Hz     4.1     44     0     0
     21     Locked     QAM256     21     549000000 Hz     4     43.9     0     0
     22     Locked     QAM256     22     555000000 Hz     4     43.9     0     0
     23     Locked     QAM256     23     561000000 Hz     4.1     43.9     0     0
     24     Locked     QAM256     24     567000000 Hz     4     43.9     0     0
     25     Locked     QAM256     25     573000000 Hz     4.1     43.9     0     0
     26     Locked     QAM256     26     579000000 Hz     4.1     43.8     0     0
     27     Locked     QAM256     27     585000000 Hz     3.9     43.7     0     0
     28     Locked     QAM256     28     591000000 Hz     4.1     43.8     0     0
     29     Locked     QAM256     29     597000000 Hz     4.1     43.8     0     0
     30     Locked     QAM256     30     603000000 Hz     3.9     43.7     0     0
     31     Locked     QAM256     31     609000000 Hz     4     43.8     0     0
     32     Locked     QAM256     32     615000000 Hz     3.9     43.7     0     0
Upstream Bonded Channels
Channel   LockedStatus  ChannelType ChannelID   SymbolRate        Frequency       Power
      1       Locked       ATDMA     18       5120 Ksym/sec       22800000 Hz       38.3 dBmV
      2       Locked       ATDMA     19       5120 Ksym/sec       29200000 Hz       39.3 dBmV
      3       Locked       ATDMA     20       5120 Ksym/sec       35600000 Hz       40.3 dBmV
      4       Locked       ATDMA     17       5120 Ksym/sec       16400000 Hz       37.5 dBmV
      5       Not Locked       Unknown      0       0       0       0.0
      6       Not Locked       Unknown      0       0       0       0.0
      7       Not Locked       Unknown      0       0       0       0.0
      8       Not Locked       Unknown      0       0       0       0.0
Downstream OFDM Channels
Channel   LockedStatus  ProfileID  ChannelID    Frequency       Power       SNR/MER    ActiveSubcarrier    Unerror    Correctable   Uncorrectable
      1     Locked     0 ,1 ,2 ,3     193     957000000 Hz     1.58 dBmV     41.4 dB     148 ~ 3947     6699720     5862969     0
      2     Not Locked     0      0     0 Hz     0 dBmV     0 dB     0 ~ 4095     0     0     0
Upstream OFDMA Channels
      1     Locked     12 ,13     43     36200000 Hz     35.5 dBmV
  • For Comcast Business accounts, there is a chance the CM3000 has not been certified for connection to the Enhanced Speed Network.
    Make a Technical Support post over on the Reddit Comcast_Xfinity forum and they should be able to give you an answer.  https://www.reddit.com/r/Comcast_Xfinity/
  • FURRYe38's avatar
    Is this speed seen with a ethernet connected PC connected directly behind the CM modem? No router in between?
    https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
    Please post a copy and paste of the modems event log page.
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    What is the brand and model of the host wifi router connected to the modem?
    • dannoz's avatar
      dannoz
      It's connected directly to a UniFi cloud gateway Max. The speed test is run on the router directly connected to the modem.
      When I connect with the Comcast provided modem CBR2-T I get 1.4 Gbps down and 400 Mbps up.
      When I change to the cm3000 the downstream stays the same and the upstream drops to 35 Mbps. Firmware V5.01.02.
      Comcast business is now saying that the CM3000 modem only supports 35 Mbps upstream.
      • FURRYe38's avatar
        Sounds like you'll need to use there modem on there business line.
