jay_w
Mar 15, 2024Apprentice
CM3000 Delivered Today
I’ve got one in hand. Going to try it out in a few hours.
Mar 15, 2024Guru - Experienced User
good luck!
Mine was rock solid on xfinity's 1.2gig/200mbps plan
- jay_wMar 15, 2024ApprenticeOh yeah! Look at that single digit ping. I forgot about registering the MAC address with xfinity of course… wasted like 30 minutes
Upload is now 5x better and I’m just under the 1.2 service on a single port. I know I can get a little more over all bandwidth if WAN aggregation works but I’d rather stick to the single multi-gig port. Photo attached.- plemansMar 15, 2024Guru - Experienced User
Nice!
what router are you using?
I know my speed will hit 1.4 but it'll bounce between the 1.2-1.4g based more off the server I'm testing on.
- jay_wMar 15, 2024ApprenticeI have the original RAX120. When I used WAN aggregation on the CM1200, I had 1.4gbs showing up as total download. But the WAN aggregation stopped working after 22-24 hours and the speed dropped down… It needed to be rebooted every day, so that didn’t work out. CM3000 doesn’t seem to have WAN aggregation which is fine for me. I just wanted to use my full service on the multi-gig ports with my ridiculous CAT8 shielded cable
I’m happy now and I’ll try to retest when the kids go to sleep.
