Jeba73's avatar
Jeba73
CM3000 direct connection to port 1 or 2 from laptop and says no internet
Just installed my CM3000 this morning and I’m waiting on my RS300 to arrive tomorrow so temporarily hooked up to my old Linksys EA9500 wireless router. It is hooked into the yellow multi-gig port and ...
  • FURRYe38's avatar
    Power OFF both CM and RS router and modem for 30 seconds then back ON with the modem and then the RS router.
    Give about 1-2 minutes. The front LED on the RS Internet globe should turn WHITE.
