Jeba73
Jan 18, 2025Aspirant
CM3000 direct connection to port 1 or 2 from laptop and says no internet
Just installed my CM3000 this morning and I’m waiting on my RS300 to arrive tomorrow so temporarily hooked up to my old Linksys EA9500 wireless router. It is hooked into the yellow multi-gig port and ...
- Jan 19, 2025
Power OFF both CM and RS router and modem for 30 seconds then back ON with the modem and then the RS router.
Give about 1-2 minutes. The front LED on the RS Internet globe should turn WHITE.
Jeba73
Jan 19, 2025Aspirant
Well, I definitely appreciate the help, but I am not getting internet on the router. I even went through the routers set up with the Nighthawk app. It shows cables connected then tests internet connection and says not connected
Jan 19, 2025Guru - Experienced User
- KitsapJan 20, 2025Master
After you restart your modem and let it connect and stabilize, does the white globe internet indicator on the modem illuminate?
