FTD92
Jun 13, 2024Aspirant
CM3000 Issues Xfinity
Hi, I am in an apartment complex at the "end of the line" so to speak when it comes to connections throughout the complex. I just recently had a technician out and when I mentioned my modem status pa...
Kitsap
Mar 15, 2025Master
Make sure your router is configured to enable IPv6 and specify Domain Name Servers (DNS) that are not the default servers from Xfinity. See attached for some options.
FTD92
Mar 15, 2025Aspirant
When I enable ipv6 on my router I actually encounter serious slow downs even when using Quad9
A partial fix was actually disabling ipv6
But I still have issues
- KitsapMar 16, 2025Master
FTD92 wrote:When I enable ipv6 on my router I actually encounter serious slow downs even when using Quad9
But I still have issuesWith IPv6 enabled, did you configure Quad9 DNS addresses for both IPv4 and IPv6? The DNS configurations are on two different pages. You also should use both primary and secondary addresses for each one.
- FTD92Mar 16, 2025AspirantYes, I just had the slow down occur again and had to reset to fix it. Disabled ipv6 again and I'm back up and running.
- FURRYe38Mar 17, 2025Guru - Experienced User
Can you test with a different router or maybe with one wired PC connected to the CM modem with out any router connected to see if the slow down happens?
From your Cable Connections and Event logs, the modem is doing good with the ISP signal. Doesn't seem to be a modem issue here.
- FTD92Mar 17, 2025AspirantThe first thing I swapped was the router. I'm getting t3 timeouts and power level errors, how does that indicate anything other than an exterior line issue?
If your getting errors in the Event log, any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/ - KitsapMar 17, 2025Master
You need to focus on the configuration of your Asus RT-BE96U. There are dozens of DNS configuration options in the settings.
Every indication is your modem is working fine. Good assistance for configuration of your router can be found on the Small Net Builders Forums. Here is a good starting point:
https://www.snbforums.com/forums/asus-be-routers-adapters-wi-fi-7.61/
