mykchicken
Apr 17, 2024Guide
CM3000 painfully slow speeds via Comcast
Hello folks - anyone else using a CM3000 and experiencing painfully slow speeds? I've ran through the typical troubleshooting (reboot, factory reset), confirmed the Modem is all green for Up/downst...
- Apr 17, 2024
Wanted to follow up on this -
I stopped by xfinity store and picked up an XB8 from them.
Plugged it in at home & within minutes I'm seeing the advertised speeds... pretty much nail in the coffin - it's the Modem that's the problem.
Going the RMA route to return it.
Truly appreciate the ideas & support of all you fine folks.
Cheers
mykchicken
Apr 17, 2024Guide
I've had their techs remove it from my account and reprovision it 3 times over the last week with no improvements, but good call out.
Attaching the cable connection screen. It's a long page đ
The only thing that jumps out is that some of the power values are a bit high...but that shouldn't cause this kind of issue, and the modem internal time is 1 hour behind but...there's no way that's an issue..right?
Good call on the exchange...at this point it's been several hours spent and it's definitely a $ net loss overall.
Apr 17, 2024Guru - Experienced User
Powers a bit too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Lets see the Events logs please.
