MojoGene
May 29, 2025Guide
CM3000 Repeated Cox disconnects with SYNC Timing Synchronization failure
The CM3000, which I have owned for <30 days, is having repeated disconnection issues. Cox is my ISP. The disconnections occur randomly, but multiple times per day and always require a hard reboot. Th...
MojoGene
May 30, 2025Guide
Event Log:
Fri May 30 14:27:11 2025 | (Critical (3)) | No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:9a:d2:d2:dd:cb;CM-QOS=1.1;CM-VER=3.1; |
Fri May 30 14:25:42 2025 | (Notice (6)) | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 10 13.;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:9a:d2:d2:dd:cb;CM-QOS=1.1;CM-VER=3.1; |
Fri May 30 14:25:29 2025 | (Warning (5)) | Dynamic Range Window violation |
Fri May 30 14:25:29 2025 | (Warning (5)) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:9a:d2:d2:dd:cb;CM-QOS=1.1;CM-VER=3.1; |
Fri May 30 14:25:24 2025 | (Notice (6)) | DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:9a:d2:d2:dd:cb;CM-QOS=1.1;CM-VER=3.1; |
Fri May 30 14:25:22 2025 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:9a:d2:d2:dd:cb;CM-QOS=1.1;CM-VER=3.1; |
Fri May 30 14:25:17 2025 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:9a:d2:d2:dd:cb;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | (Warning (5)) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:9a:d2:d2:dd:cb;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv4 |
Time Not Established | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
