MojoGene
May 29, 2025Guide
CM3000 Repeated Cox disconnects with SYNC Timing Synchronization failure
The CM3000, which I have owned for <30 days, is having repeated disconnection issues. Cox is my ISP. The disconnections occur randomly, but multiple times per day and always require a hard reboot. Th...
iFrog
Jun 06, 2025Guide
Also, because I can't edit my last post to add this, I prefer the S33 as it has the 2.5G port and even with a 1G package, having a 2.5 connection gives you the full Gigi so not capped at 940 Mbps.
