LanceS4803
Aug 19, 2015Aspirant
CM400 Cable Modem Getting Very Hot
I recently purchased a Netgear CM400 High Speed Cable Modem and noticed that it is operating at an apparently very high temperature. The body of the modem itself is hot, especially on the bottom, in...
DarrenM
Aug 20, 2015Sr. NETGEAR Moderator
Hello LanceS4803
Yes it shouldn't be that hot do you have your modem in a open area and not stuffed in a entertainment center with other electronics if so and its still getting hot I would swap it out at where you purchased it or contact Netgear support and have it exchanged.
DarrenM
LanceS4803
Aug 20, 2015Aspirant
Thanks Darren.
It is out in the open on a decktop, and also in it's stand to expose top and bottom.
Will swap it out.
