NayNay73
May 06, 2020Aspirant
CM400 Changing from 2.4ghz to 5ghz
Hello and Thanks for the help in advanced! I am trying to change to 5ghz. I have went into the modem settings and there arent many options to pick from as I tried to use other users answers to th...
May 06, 2020Guru - Experienced User
The CM modem is a modem only so no router or wifi configurations will be seen on the CM modem. Consult your wifi routers user manual for information on how to configure and operate the wifi router.
