Squelch's avatar
Squelch
Follower
Apr 03, 2018
CM400 constantly losing connection during large uploads
I am on Cox using a CM400 with the latest (1.01.17) firmware. Whenever I do a large backup (uploading >1Gb of data) the modem loses the internet connection after a period of time - sometimes less than ten minutes, sometimes an hour or more. Here are my logs/data
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUnCorrectables
1LockedQAM 25617879000000 Hz0.9 dBmV37.0 dB11543
2LockedQAM 25618885000000 Hz0.5 dBmV37.0 dB24483
3LockedQAM 25619891000000 Hz0.8 dBmV37.0 dB341338
4LockedQAM 25620897000000 Hz1.0 dBmV37.6 dB35608
5LockedQAM 25621903000000 Hz1.3 dBmV36.6 dB51634
6LockedQAM 25622909000000 Hz1.3 dBmV37.6 dB67634
7LockedQAM 25623915000000 Hz1.6 dBmV37.9 dB20613
8LockedQAM 25624921000000 Hz1.6 dBmV37.3 dB30624
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA12560 Ksym/sec18400000 Hz43.0 dBmV
2LockedATDMA25120 Ksym/sec23300000 Hz45.0 dBmV
3LockedATDMA35120 Ksym/sec29800000 Hz45.0 dBmV
4LockedATDMA45120 Ksym/sec36300000 Hz45.0 dBmV
TimePriorityDescription
Apr 2 21:54:13 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 2 21:54:13 2018Notice (6)TLV-11 - unrecognized OID
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out
Apr 2 22:20:10 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 2 22:20:10 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 07:46:02 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 07:46:03 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 07:50:27 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 07:50:27 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 08:48:27 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 08:48:27 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 09:04:23 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 09:04:23 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 09:20:28 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 09:20:28 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 10:00:46 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 10:00:46 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 10:06:31 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 10:06:31 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 10:30:01 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 10:30:01 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 11:07:57 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 11:07:57 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 11:30:39 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 11:30:39 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 11:34:52 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 11:34:52 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 11:39:07 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 11:39:07 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 11:55:43 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 11:55:43 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 12:36:13 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 12:36:13 2018Notice (6)TLV-11 - unrecognized OID
Apr 3 13:42:46 2018Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Apr 3 13:42:46 2018Notice (6)TLV-11 - unrecognized OID
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Squelch
    I am seeing some T3 timeouts in your logs this typically is a issues with your cable company connection I would contact them and have a tech investigate your area.
    DarrenM
