russ0304
Jun 23, 2017Aspirant
CM400 firmware problem
The firmware on my CM400 was upgraded by Comcast from v1.01.17 to v1.01.18. Now the event log will not open using Firefox v54 or IE11. In Firfox it just shows the spinning wheel, in IE11 error "Can't...
DarrenM
Jun 26, 2017Sr. NETGEAR Moderator
Hello russ0304
Have you tried chrome?
DarrenM
russ0304
Jun 26, 2017Aspirant
No, and don't intend to. I use Firefox and just tried IE because I have it.
- DrHitchJun 30, 2017Aspirant
I replaced my Arris modem (Time-Warner furnished) with a NetGear CM400. I called them to change the MAC address. At first, it worked fine (both hardwired to PC as well as to my NetGear WiFi router.
But after 2 hours, the modem lights droped down to "no internet" and flashing "uplink".....The support people at T/W did a bunch of stuff inside my PC (DNS, IPconfig, etc) to no avail.
1) How do Ifind the firmware version of this modem?
2) Why does T/W have such a hard time getting this MAC address change to work?
3) I reverted back to their Arris modem and it seems to be fine again, but I want to usse my purchased CM400
- DarrenMJul 03, 2017Sr. NETGEAR Moderator
Hello DrHitch
You may want to call back and ask for there tier 3 internet support sounds like they did not code you account correctly for the new modem and the old one is still on the account.
DarrenM
