cmhscm's avatar
cmhscm
cm400 modem drops internet connectivity
I have a cm400 modem that periodically drops the internet connection with Comcast. The ethernet and upstream lights blink for several minutes, eventually re-establishing connectivity. The modem log indicates the following timeout messages occurring over the course of about 10 minutes: T3, T3, T4, T3, T2. Then a connection is made. This happens a couple of times each day. I've checked all cable connections and they seem fine. Is this a problem with the modem (less than 1 year old), or with the connections (mine or Comcast)? Thanks.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    those timeouts typically indicate a issue with the ISP could be lines in your neighborhood are bad.
    DarrenM
    • cmhscm's avatar
      cmhscm
      Thanks! I'll follow with Comcast. Thanks again.
