oneplace
Mar 31, 2016Follower
CM400 Modem ethernet light blink yellow
CM400 Modem ethernet light blink ambler only when the router is connected, with out the router it is the same as all the other lights Does any one no why? I have tried different routers and differe...
ElaineM
Apr 05, 2016NETGEAR Employee Retired
Hi oneplace
Welcome to the community!
Amber Ethernet light means that the device connected to it is running on 10/100Mbps only.
The Ethernet port is capable of up to 1000Mbps.
- LinsJul 22, 2016Aspirant
so that light blinks like that because the wireless router it's connected to has a slow speed? Is it a problem? My wireless router is at least 10 years old (linksys wireless g wrt546)... It still works so I've held off on replacing it. I bought the cm400 because I was tired of paying the cable company....
- DarrenMJul 25, 2016Sr. NETGEAR Moderator
Hello Lins
No problem at all it should work like that with older equipment.
DarrenM
