walkerr8
Jul 12, 2016Aspirant
CM400 Modem lights flashing quickly but not working
Came home from a vacation trip and my modem (which was purchased 5 months ago) is not working. Power light is flashing really fast and a couple other lights are flashing fash as well but nothing is w...
walkerr8
I'm not currently home but I have unplugged it numerous times. Pretty sure it had a small hole for me to put a paper clip in and reset which I also did a couple times. Any other ways to reset it?
VE6CGX
Jul 12, 2016Master
You already tried then. Time to call your ISP tech support if the unit is supplied by them.
- walkerr8Jul 12, 2016Aspirant
It's not. I purchased it myself in February.
- VE6CGXJul 12, 2016Master
UPS = Uninterrupted Power supply with rechargeable battery back up.
Came home and here's a little more detailed info. When plugged in the power light, 2 lightning bolt lights and the light on the bottom are all flashing at the exact same time which is about every 1/2 second. I just put a paper clip in the back reset button and held it down for 10 seconds and it still continued to do the same flashing.
