brabq
Feb 08, 2021Aspirant
CM400: Post-Reset Fast Speeds, then Slow (Downstream Channel Shift?)
I have a CM400 (Netgear) cablemodem, which has worked fine for the last several years. In the last 24 hours, however, I've seen it slow to a crawl. Resetting the cable modem - whether I do it, or Xfi...
- Feb 08, 2021
For what it's worth, and for anyone that should find this in the future. Oddly enough, disconnecting the CM400 from power for some time (minutes) before reconnecting it seems to have solved the issue. Now, the uptime has been >60 minutes and the modem has continued to use the initial/boot downstream channel and has not "chased" the apparently bad-choice downstream channel as it previously had. I hope this helps someone else.
Feb 08, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
brabq
FURRYe38:
Thanks. Here's what the page looks like currently. I have performed several resets, and - like clockwork - at "uptime" of 13m0s is when it switches downstream channels and the quality drops.
- brabqFeb 08, 2021Aspirant
