xLyrical
May 21, 2020Tutor
CM400 Router suddenly very slow, briefly fast after a reset
Hi, I have a CM400 modem that I've had and actively used for nearly 3 years without issue. Suddenly, yesterday (and today), my speeds were painfully slow, clocking in at 1.5 - 2.5Mpbs downlink (norma...
- May 21, 2020
Thanks for the insight and tip! It seems I was able to solve the issue after isolating the problem to the router. Hardwire connection to the modem gave me the proper speeds (I had hard connected through the router previously, doh!). Unplugging both modem and router for 15 minutes and then getting them back online seems to have done the trick...heading into almost an hour with a stable fast connection now. Hopefully this was all that was needed!
Thank you!
May 21, 2020Guru - Experienced User
xLyrical wrote:
I've contacted my cable company (Cox) and they ran some tests on their side and said there is nothing wrong with the network and that their testing to my modem shows that there is some interal failure causing the issue. As usual, with cable companies, I'm a bit of a skeptic so I wanted to see if anyone here could offer me any insight or advice on what to do or try to fix the issue? This has never happened before and it hasn't improved since last night thoughout today with the exception of the few minutes each time I power cycle.
Very aptly put. They're very good at blaming 3rd party equipment.
to start with, if you have any splitters, attenuators, or amplifiers in the coax line. remove them. Also, directly connect the modem right where the coax enters the home. This prevents devices in line or the coax within the walls from being the issue.
Use it for a bit (however long it took to drop speeds). If they drop again, log into the modem and go to the cable connection page and get a screen snip of that and your logs. That shows us the connection back to the isp. I'd also recommend just directly connect a pc to the modem for this so you can be sure it isn't a router issue causing the slow downs.
xLyrical
May 21, 2020Tutor
Thank you!
