Squidge's avatar
Squidge
Follower
Apr 27, 2017
CM450 1TLAUS Unable to log in under admin and cannot find Router model on community page
Hey all   Telstra setup my wifi router the other day and I just went to change the login detais from the stock admin password, but its saying it is incorrect.   Pressing the reset button has not ...
  • DarrenM's avatar
    May 03, 2017
    Hello squidge
    You will need to hold the reset button for 10 seconds this will factory reset the unit and then you should be able to login with admin password.
    DarrenM
