PhantomHawks
Sep 12, 2020Aspirant
CM500 - Upstream channels not locking
Just in the last few days have noticed random - but severe - amounts of lag while gaming on a PS4 Pro. Noticed that a light was amber on my modem. Reset the modem and it went away and everything wa...
Sep 13, 2020Guru - Experienced User
You upstream power levels are boarderline high.
and t3/t4 errors tend to be line issues. Not modem issues.
If you have any splitters, amplifiers, attenuators ran in the coax line, remove them.
- PhantomHawksSep 13, 2020Aspirant
So today all the lights are green on the modem, and all upstream channels are locked...
I didn't change anything. I came out to look at the router this morning and it was all green. Checked the modem and found all upstream channels are locked.
There is a splitter to my cable tv box and that's it.
- FURRYe38Sep 14, 2020Guru - Experienced User
Would be on the ISP side of things they may have changed something on the line.
