PhantomHawks
Sep 12, 2020Aspirant
CM500 - Upstream channels not locking
Just in the last few days have noticed random - but severe - amounts of lag while gaming on a PS4 Pro. Noticed that a light was amber on my modem. Reset the modem and it went away and everything wa...
Sep 13, 2020Guru - Experienced User
You upstream power levels are boarderline high.
and t3/t4 errors tend to be line issues. Not modem issues.
If you have any splitters, amplifiers, attenuators ran in the coax line, remove them.
PhantomHawks
Sep 13, 2020Aspirant
So today all the lights are green on the modem, and all upstream channels are locked...
I didn't change anything. I came out to look at the router this morning and it was all green. Checked the modem and found all upstream channels are locked.
There is a splitter to my cable tv box and that's it.
- FURRYe38Sep 14, 2020Guru - Experienced User
Would be on the ISP side of things they may have changed something on the line.
