cyclonesbball24
Nov 19, 2024Aspirant
CM500 - Upstream light is Amber
Hi there - my modem is a CM500 and just recently the upstream light has turned to solid amber which is causing me some connection issues. Below are my cable connections and event logs.Thank you in ad...
cyclonesbball24
I forgot to add, I just tried a new coax cable this evening and it did not fix it.
