cyclonesbball24
Nov 19, 2024Aspirant
CM500 - Upstream light is Amber
Hi there - my modem is a CM500 and just recently the upstream light has turned to solid amber which is causing me some connection issues. Below are my cable connections and event logs.Thank you in ad...
Nov 19, 2024Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
- plemansNov 20, 2024Guru - Experienced User
Your logs indicate a line issue back to the ISP.
Follow the advise from above and see if it helps.
I recommend directly connecting the modem to the line that first comes into the house. That rules out things in the house causing issues such as the wiring in the walls/jacks/etc.
If that doesn't help, time to call the isp
