Florida712
Feb 10, 2020Follower
CM500-100NAS - Loosing connection - SYNC Timing Synchronization failure
Hello All, I have a CM500-100NAS, which while a couple of years old worked flawlessly until about 2 weeks ago, my firmware seems up to date as V1.01.12. I have since experienced many many dropped c...
Feb 11, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Florida712 wrote:Hello All,
I have a CM500-100NAS, which while a couple of years old worked flawlessly until about 2 weeks ago, my firmware seems up to date as V1.01.12.I have since experienced many many dropped connections, I can see that it is on my modem side using Apple Airport utility.
I had Xfinity out here yesterday and they measured and all is ok from their side, they tightened some connections but couldnt see anything really. The technician noted that I have part of the old cable R59 in between the ISP box and my modem. (But this has not been an issue for the last 3 years we have been living here).After resetting the modem and the router I have now looked into the error logs of the modem and find this:
It is a mix of SYNCH Timing failure, where the date shows as 1970 .... and Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out.
Any advise would be highly appreciated.
Thanks a lot
