SteveUSA1
Feb 03, 2022Aspirant
CM500-100nas amber upstream light - available channels vs number of channels shown
I've tried searching this and haven't seen a direct question or answer to this question, only references. If missed it somewhere else I apologize. My modem is a CM500-100NAS and my ISP is Spectrum. ...
- Feb 03, 2022
I would ask the ISP how many channels they using for the UP. If they say more than one then possible the modem maybe faulty.
Might ask them as well if there is any FW available from them they could push.Have the ISP check the signals and line up tot the modem to be sure.
Check all cables, connections and coax connectors. Some times connectors can be bad, go bad or not properly made in the first place.
SteveUSA1
FURRYe38 I appreciate the fast response and suggestions. I also saw those during my searching and will definately do them after work however, I think you overlooked my question:
How many, in total, upstream channels should be seen in the status screen? IE: If there are 4 channels and only 1 bonded, should I see only the 1 bonded channel or should I see 3 unbonded channels and 1 bonded.
Based on screenshots from other posts, unbonded channels are listed along with the bonded channels but I want to confirm if that is always the case or not.
SteveUSA1
Here is my view of the status page:
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 10 669000000 Hz -4.9 dBmV 40.1 dB 2 0
2 Locked QAM256 1 615000000 Hz -5.2 dBmV 39.9 dB 4 0
3 Locked QAM256 2 621000000 Hz -5.4 dBmV 39.7 dB 5 0
4 Locked QAM256 3 627000000 Hz -5.6 dBmV 39.7 dB 3 0
5 Locked QAM256 4 633000000 Hz -5.1 dBmV 39.9 dB 5 0
6 Locked QAM256 5 639000000 Hz -5.4 dBmV 39.8 dB 1 0
7 Locked QAM256 6 645000000 Hz -4.8 dBmV 40.1 dB 7 0
8 Locked QAM256 7 651000000 Hz -5.5 dBmV 39.8 dB 4 0
9 Locked QAM256 8 657000000 Hz -4.8 dBmV 40.1 dB 11 0
10 Locked QAM256 9 663000000 Hz -5.2 dBmV 40 dB 7 0
11 Locked QAM256 11 675000000 Hz -5.2 dBmV 39.7 dB 4892 15964
12 Locked QAM256 12 681000000 Hz -5.2 dBmV 40 dB 5077 22375
13 Locked QAM256 13 687000000 Hz -5 dBmV 40.1 dB 5 0
14 Locked QAM256 14 693000000 Hz -5.3 dBmV 40 dB 5 0
15 Locked QAM256 15 699000000 Hz -4.6 dBmV 40.2 dB 2 0
16 Locked QAM256 16 705000000 Hz -4.9 dBmV 40.1 dB 11 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 1 5120 Ksym/sec 17600000 Hz 57 dBmV
Current System Time:Thu Feb 03 18:17:15 2022
