fela
Nov 06, 2019Aspirant
CM500-100NAS Bad Ping
Hi, I recently purchased this modem from Amazon. https://www.amazon.com/gp/product/B06XH46MWW/r The ping is terrible and I exhibit significant packet loss. Online gaming isn't possible. I use...
- Nov 08, 2019
Awesome, glad it was fixed. Please mark your thread as solved so others will know. Enjoy. :smileywink:
Nov 06, 2019Guru - Experienced User
Are you using the CM modem with your gaming device or is there a router in between the CM modem and your gaming device? If so, Mfr and model# of this router please.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
fela wrote:Hi,
I use http://ping-test.net/ to verify my issues.
Ping jumps to the the hundreds of milliseconds. Performance I tested connected directly to the modem, so it's not a router/wifi issue.. Comcast verified the connection was good from their end and I want to see if anyone has any suggestions before I call the tech or buy a different modem.
Thanks
fela
Nov 08, 2019Aspirant
Thanks for your help. Comcast had a filter on the main line on the street that they removed. I have no idea why it was there to begin with.
That was the problem.
