raymondjtoth
Mar 07, 2022Guide
CM500-100NAS help thanks
hi i have CM500-100NAS help thanks and fixed the lines last i posted not the modem is radiomly losing channle bonding on down stream here 192.168.100.1 info you need Cable Connection ...
raymondjtoth
Mar 08, 2022Guide
yes understand you do on own time what i tell isp to havve them fix it thay replayed all lines from house tpo lockboix and poll last time youi helped me.
raymondjtoth
Mar 08, 2022Guide
ok of this message im chatting with tech supporet telling them there error in line and what told me thanks what eles i tell them thanks?
- plemansMar 08, 2022Guru - Experienced User
did you check all your connections?
Again, your power is out of spec, (should be within 3.5dbmv of each other), you have channels that aren't locked, and your log is indicating connection issues to the cmts.
- raymondjtothMar 08, 2022Guide
yes last tech who came out replaced all lines from poll to lockbox and lockbox to inside house
then its either something at the pedastal, inside the home, or with the modem. Or the did a poor job of installing.
