raymondjtoth
Mar 07, 2022Guide
CM500-100NAS help thanks
hi i have CM500-100NAS help thanks and fixed the lines last i posted not the modem is radiomly losing channle bonding on down stream here 192.168.100.1 info you need Cable Connection ...
Mar 08, 2022Guru - Experienced User
the pick up a 2 way splitter.
You want the modem getting the best possible signal you can get.
raymondjtoth
Mar 08, 2022Guide
so modem on drect line right to outside and rest in splitter right?
- raymondjtothMar 08, 2022Guide
also i called tech support sed outige after ment i talked to from tech support herre what getting now
Cable ConnectionFrequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 615000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 10 615000000 Hz 4.8 dBmV 42.2 dB 0 0 2 Locked QAM256 1 561000000 Hz 5.3 dBmV 43.2 dB 0 0 3 Locked QAM256 2 567000000 Hz 5.5 dBmV 43.2 dB 0 0 4 Locked QAM256 3 573000000 Hz 4.3 dBmV 42.1 dB 0 0 5 Locked QAM256 4 579000000 Hz 4.1 dBmV 41.8 dB 0 0 6 Locked QAM256 5 585000000 Hz 5 dBmV 42.1 dB 0 0 7 Locked QAM256 6 591000000 Hz 4.3 dBmV 41.9 dB 0 0 8 Locked QAM256 7 597000000 Hz 3.6 dBmV 41.8 dB 0 0 9 Locked QAM256 8 603000000 Hz 3.4 dBmV 41.9 dB 0 0 10 Locked QAM256 11 621000000 Hz 4.5 dBmV 41.3 dB 0 0 11 Locked QAM256 12 627000000 Hz 4.4 dBmV 38 dB 0 0 12 Locked QAM256 15 645000000 Hz 5.2 dBmV 40.4 dB 0 0 13 Locked QAM256 21 687000000 Hz 8 dBmV 43 dB 0 0 14 Locked QAM256 22 693000000 Hz 7.1 dBmV 42.6 dB 0 0 15 Locked QAM256 23 699000000 Hz 6.8 dBmV 42.8 dB 0 0 16 Locked QAM256 27 723000000 Hz 5.6 dBmV 41.4 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 24600000 Hz 43 dBmV 2 Locked ATDMA 1 2560 Ksym/sec 18000000 Hz 43 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 31000000 Hz 43.5 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 37400000 Hz 43.5 dBmV Extended Upstream Transmit Power Enable Extended Upstream Transmit Power
Current System Time:Tue Mar 08 22:23:24 2022System Up Time:00:03:16
any better?
- plemansMar 08, 2022Guru - Experienced User
Much better. No current errors.
Time, your logs, and if it stays stable will be the key.
