katPHish's avatar
katPHish
CM500 and sporadic issues on Comcast\Xfinity
Things seems sluggish of late.  Need some help before contactng Comcast again as they as me to check with Netgear first.   Info from this morning:
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1LockedATDMA135120 Ksym/sec34800000 Hz37.3 dBmV
2LockedATDMA145120 Ksym/sec27900000 Hz37.3 dBmV
3LockedATDMA155120 Ksym/sec21000000 Hz36 dBmV
4LockedATDMA162560 Ksym/sec14100000 Hz35 dBmV
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1LockedQAM2561609000000 Hz1.8 dBmV39.5 dB2279
2LockedQAM2562615000000 Hz1.7 dBmV39.4 dB3331
3LockedQAM2563621000000 Hz1.8 dBmV39.5 dB4270
4LockedQAM2564627000000 Hz1.9 dBmV39.4 dB3565
5LockedQAM2565633000000 Hz1.9 dBmV39.4 dB5935
6LockedQAM2566639000000 Hz1.8 dBmV39.2 dB4024
7LockedQAM2567645000000 Hz2.2 dBmV39.4 dB1859
8LockedQAM2568651000000 Hz1.9 dBmV39.2 dB5038
9LockedQAM2569657000000 Hz1.8 dBmV39.2 dB5627
10LockedQAM25611669000000 Hz1.8 dBmV39.1 dB2361
11LockedQAM25612675000000 Hz1.6 dBmV38.4 dB3694
12LockedQAM25613681000000 Hz1.7 dBmV39 dB2741
13LockedQAM25614687000000 Hz1.6 dBmV38.9 dB41126
14LockedQAM25617705000000 Hz1.8 dBmV39 dB22526
15LockedQAM25621729000000 Hz1.1 dBmV38.7 dB479
16LockedQAM25624747000000 Hz0.6 dBmV38.4 dB2419
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel609000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
Configuration File
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Alot of these in log:
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=X;CMTS-MAC=X;CM-QOS=1.1;CM-VER=3.0;
SYNC Timing Synchronization failure - Failed to acquire FEC framing;
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
Dynamic Range Window violation
A lot more of these:
No Ranging Response received - T3 time-out
Have a few entries with a date time of:
1970-1-1, 00:00:XX
