Mikerod72
Oct 27, 2019Aspirant
CM500 Blinking Lights
I had been using a CM400 with my Spectrum internet but in the last month was getting service interruptions more and more frequently so I decided to purchase a CM500 thinking maybe my modem was the iss...
Oct 27, 2019Guru - Experienced User
If you log into your modem, can you post a screen shot of your connections page?
I'd also recommend removing any splitters, amplifiers, 90 degree elbows, extended runs, cheap connections, or kinked cables from you line.
