inky_thoughts
Jul 31, 2020Tutor
CM500 Cable Modem Creating Double NAT
Setup: CM500-100NAS on Firmware v1.01.05 Cable Modem Ethernet out to eero Gateway wireless router Xbox One five feet from router, connected wirelessly For a couple weeks, I've shown a strict NA...
- Jul 31, 2020
> [...] a double NAT would mean I have NAT happening on the modem as
> well as the router. [...]Well, somewhere, but a modem can't do it. Another possibility:
https://en.wikipedia.org/wiki/Carrier-grade_NAT
> [...] I'm wondering if it's something jacked up on the ISP side.
Carrier-grade NAT would qualify.
Have you looked at the IP address of the WAN/Internet interface on
your router? Plug that address into the form at:
https://whois.arin.net/ . Is it a public address or a private address?
antinode
Jul 31, 2020Guru
inky_thoughts
Jul 31, 2020Tutor
That’s really helpful. Everything seems to point to a carrier-grade NAT system.
Using whatsmyip.org and Whois, my ip from my ISP is not the same as the ip on my router.
Looks like I’m up the creek.
