inky_thoughts's avatar
Jul 31, 2020
CM500 Cable Modem Creating Double NAT
Setup: CM500-100NAS on Firmware v1.01.05 Cable Modem Ethernet out to eero Gateway wireless router Xbox One five feet from router, connected wirelessly   For a couple weeks, I've shown a strict NA...
  • antinode's avatar
    Jul 31, 2020
    > [...] a double NAT would mean I have NAT happening on the modem as
    > well as the router. [...]
       Well, somewhere, but a modem can't do it.  Another possibility:
          https://en.wikipedia.org/wiki/Carrier-grade_NAT
    > [...] I'm wondering if it's something jacked up on the ISP side.
       Carrier-grade NAT would qualify.
       Have you looked at the IP address of the WAN/Internet interface on
    your router?  Plug that address into the form at:
    https://whois.arin.net/ .  Is it a public address or a private address?
