RAYANS
Jul 11, 2020Follower
CM500 capped at 100Mbps
I replaced the xfinity cable modem with the CM500-1AZNAS modem. The download speed is stuck at 92Mbps. my earlier xfinitiy cable modem was getting me 200+Mbps. Called Xfinity and they could not sol...
Jul 12, 2020Guru - Experienced User
have you tried replacing the ethernet cable? make sure its cat5e or greater.
What computer is it? It sounds like you're connected at a fast 10/100mbps connection and not gigabit.
any other computers you can try testing with?
are you directly connected to the modem or is there a router connected? if so, what router is connected?
