Buzzik
Mar 20, 2021Tutor
CM500 Comcast ASYNC issue
fdHello everyone. I have this weird issue with my connection. I have Xfinity and my speed is around 120Mbps DLD/5mbps UPLD. I am gaming a lot, mostly fast paced shooters where good connection is ess...
Mar 20, 2021Guru - Experienced User
Its normal to get that after a reboot.
If the modems been running/used for a while, when it slows down, do you get the same error that corresponds to the time the drop happens in the game.
Buzzik
Mar 21, 2021Tutor
No, same count. It drops just onse
- plemansMar 21, 2021Guru - Experienced User
So it only drops when you first startup the modem. Nothing afterwards?
And more than 1 modem had the same issue?
If so, I wouldn't be looking at the modem
- BuzzikMar 21, 2021TutorYes, same with another modem, internet drops just 1 time. Had Comcast guy this morning, he said the outlet is perfectly good and he does not know what this might be, đ.
