Mike1243
Sep 04, 2015Follower
CM500 connected to N600
I recently upgraded my cable modem to CM500 and wireless router to N600 to take advantage of new services in my areas. Since changing I am experiencing two frustrating issues. 1. CM500 frequentl...
DarrenM
Sep 08, 2015Sr. NETGEAR Moderator
Hello Mike1243
First i would check your connections make sure the modems cable cord is tight and also if you have a cable splitter try to bypass that see if that helps your upload issue. Maybe swap Ethernet cables to make sure you don't have a bad one. As for the speeds make sure you don't have Qos enabled this could be directing your bandwidth. On the wireless is this happening on both the 2.4 and 5ghz? This could be caused by a older device connecting to the wireless slowing the speed down so I would test it with your newest wireless device without any others connected to see if its still slow. hope to hear your feedback.
DarrenM
