Gina11
Mar 17, 2020Tutor
CM500 connectivity issues - Cox has no advice - log shows variety of critical errors
Hello, I have been having problems with freqent internmittent Internet connectivity for weeks. I have a CM500-100NAS modem and an Orbi router with satellite. The modem frequently shows either blink...
Mar 17, 2020Guru - Experienced User
take a screen snip of the modem's connection page. it should show things like upload/download-snr/etc.
that helps show your connection to the isp with the logs.
if you have any splitter, attenuators, amplifiers in line, remove them.
also prefereable to mode the mode to right where the coax enters the home. this prevents the wiring within the walls from being an issue.
check all connectors for corrosion/loose/cheap/bad.
- Gina11Mar 18, 2020Tutor
plemans, thank you for your reply. I did as you suggested. Checked connections, cords, etc. No splitters, etc. As a precaution I also removed my T Mobile cell spot that was plugged into the router.
This morning the downstream link was blinking amber while the upstream was green solid. My dashboard also showed all 4 uplinks locked, unlike yesterday when I only had 1.
Now it is 6 hours later, and I have reverted to the same situation. The upstream has amber blinking light and 1 upstream locked. I have attached a pdf of the dashboard as you requested. The one labeled March 18 is from this morning, while the one labeled March 18 PM was taken just 7 hours later. I appreciate any suggestions!
