Zathura610
Apr 01, 2019Follower
CM500 Constant red light
My Modem's power LED is a constant red, and is preventing me from connecting to the internet. Holding down the reset button does nothing, and after leaving it unplugged from power for a few minutes n...
gonediving01
Apr 28, 2019Aspirant
My router did the same. When I unplugged power the red light stayed on. So I unplugged the coaxial cable input the router. The power light went out. When I plug power back in the power light was white and started booting up. Plug the coax cable back in and everything was ok. The reset button did work when the light was red.
gonediving01
Correction to my previous post the reset button did NOT work when the power light was red.
