randykepple's avatar
randykepple
Cm500 disconnection issues
Performed a search and similar topics were marked resolved, so I'm starting a new one. First of all, I purchased this new model towards the end of February (2016) because I was having issues with dis...
  • DarrenM's avatar
    May 27, 2016
    Hello randykepple
    Typically when you see T3 and T4 timeouts its a line issue with the ISP but if they are claiming its the modem after checking it out I would try to swap it out just to make sure it is not the modem that is having issues.
    DarrenM
