eltoman's avatar
eltoman
Follower
Aug 19, 2021
CM500 dropping connection
Hello, and thank you in advance for your help.
I have had CM500 cable modem for 2+ years. It has worked great until the last week or so when it began losing connection. Initially, I power cycled the unit and it seemed to come back on. At first, it was fine for a couple of days before our connectivity was down again. Then yesterday it went down repeatedly throughout the day.
I am pretty limited in my troubleshooting skills. With the multiple drops yesterday, I power cycled the unit and then logged in to the modem. I've copied the cable connection information as well as a copy of the event log below.
I'm wondering if this is a modem issue or may be an issue with our cable connection. We had some ongoing issues with our ISP (WOW!) a few years ago but they upgraded their service lines in our neighborhood and things have worked consistently well since then. In case this may be relevant, we've had some pretty big rain storms recently and I've wondered if that could affect things.
Thank you for any help you may be able to provide. Please let me know if I can provide any additional information.
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel507000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2561507000000 Hz-9.9 dBmV39 dB00
2LockedQAM2562513000000 Hz-10 dBmV35.2 dB00
3LockedQAM2563519000000 Hz-11 dBmV37.7 dB00
4LockedQAM2564525000000 Hz-10.7 dBmV35.6 dB00
5LockedQAM25616597000000 Hz-12.1 dBmV38 dB00
6LockedQAM25619615000000 Hz-11.7 dBmV38.3 dB1221
7LockedQAM25620621000000 Hz-11.6 dBmV38.3 dB330
8LockedQAM25621627000000 Hz-12 dBmV38.1 dB1023
9LockedQAM25622633000000 Hz-11.9 dBmV38 dB330
10LockedQAM25623639000000 Hz-12.5 dBmV37.6 dB330
11LockedQAM25624645000000 Hz-11.7 dBmV38.2 dB607
12LockedQAM25625651000000 Hz-12.2 dBmV37.9 dB2018
13LockedQAM25626657000000 Hz-12 dBmV38 dB691
14LockedQAM25627663000000 Hz-12.4 dBmV37.6 dB10726
15LockedQAM25628669000000 Hz-12.3 dBmV37.7 dB24480
16LockedQAM25632693000000 Hz-12.2 dBmV37.9 dB3440393
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA75120 Ksym/sec31000000 Hz52.5 dBmV
Current System Time:Thu Aug 19 06:50:57 2021
TimePriorityDescription
2021-8-18, 21:29:33Notice (6)TLV-11 - unrecognized OID;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.1;CM-VER=3.0;
2021-8-18, 21:29:41Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 21:29:49Notice (6)Honoring MDD; IP provisioning mode = IPv4
2021-8-18, 21:29:52Notice (6)TLV-11 - unrecognized OID;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.1;CM-VER=3.0;
2021-8-18, 21:30:00Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 21:30:09Notice (6)Honoring MDD; IP provisioning mode = IPv4
2021-8-18, 21:30:14Notice (6)TLV-11 - unrecognized OID;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.1;CM-VER=3.0;
2021-8-18, 22:40:26Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.1;CM-VER=3.0;
2021-8-18, 22:41:46Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:41:47Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:42:45Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:42:46Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:43:45Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:43:46Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:44:57Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:44:58Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:45:59Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:46:00Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:46:58Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:46:59Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:48:11Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:48:12Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:49:18Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:49:19Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:50:17Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:50:18Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:51:14Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:51:15Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:52:27Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:52:28Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:53:32Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:53:33Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:54:44Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:54:45Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:55:07Notice (6)Honoring MDD; IP provisioning mode = IPv4
2021-8-18, 22:55:10Notice (6)TLV-11 - unrecognized OID;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.1;CM-VER=3.0;
2021-8-18, 22:55:12Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:55:17Critical (3)No Ranging Response received - T3 time-out;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.0;CM-VER=3.0;
2021-8-18, 22:56:19Notice (6)Honoring MDD; IP provisioning mode = IPv4
2021-8-18, 22:56:23Notice (6)TLV-11 - unrecognized OID;CM-MAC=14:59:c0:7f:d3:d0;CMTS-MAC=00:01:5c:6a:f8:52;CM-QOS=1.1;CM-VER=3.0;
1 Reply
  • plemans's avatar
    Are you using any splitters or signal attenuators in your line?  you''re below optimial spec on  your power.
    If you have those, remove them. With being below spec, if it varies to low, you'll have issues. And that signal strength can change throughout the day.
    Your logs indicate line issues and your power levels show you as low. so I'd check the line for anything that can decrease power. Like the signal attenuator or splitter. Also check the line for kinks, damage, loose/old/bad/corroded connectors, or extended runs.
