jgreenex
Jun 30, 2022Aspirant
CM500 Errors and latest Firmware
I consistently get the following errors. Typically they coincide with a brief connectivity outage. 2022-6-29, 06:39:07 Notice (6) TLV-11 - unrecognized OID;CM-MAC=10:0c:6b:6a:8b:18;CMTS-M...
jgreenex
I had one of the disconnects this afternoon and sent these logs to my ISP
| 2022-6-30, 15:04:44 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:6a:8b:18;CMTS-MAC=00:01:5c:7b:3a:4c;CM-QOS=1.1;CM-VER=3.0; |
| 2022-6-30, 15:05:07 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| 2022-6-30, 15:05:12 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=10:0c:6b:6a:8b:18;CMTS-MAC=00:01:5c:7b:3a:4c;CM-QOS=1.1;CM-VER=3.0; |
| 2022-6-30, 15:05:12 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=10:0c:6b:6a:8b:18;CMTS-MAC=00:01:5c:7b:3a:4c;CM-QOS=1.1;CM-VER=3.0; |
| 2022-6-30, 15:05:16 | Error (4) | Improper Configuration File CVC Format |
Their response:
I apologize for the issues that you are experiencing. As we have already completed a monitor on your modem, and the multiple times of contact between you and us, we have not seen any issues with your modem whatsoever. Unfortunately, we do not go by those logs. The statistics of this modem have not changed over the course of a few days so we do not see any problems with the service. I know as you have previously asked about upgrading firmware, this is not something Service Electric Cablevision will do as you have a third-party Netgear modem. For all of this, this is something you would need to contact Netgear directly for.
I did have a cable splitter, which is now removed from the equation. I'll post if that helps.
Jun 30, 2022Guru - Experienced User
Well your on the lower fringes of the power being a bit too low. Would be good if the power could come up just a bit.
Hoping the removal of the splitter can help.
All those events posted can only be controlled by the ISP. The mode is just reporting what is happening.
You have a few correct and un-correctables. Ensure all connections and fittings are snugg.
Good quality RG6 coax cable is recommended.
- jgreenexJul 01, 2022Aspirant
Removing the splitter had a definite impact on the power. I'm really hoping this resolves this issue. Time will tell!
Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 1 651000000 Hz 0.6 dBmV 38 dB 0 0 2 Locked QAM256 10 561000000 Hz 1 dBmV 37.8 dB 0 0 3 Locked QAM256 12 573000000 Hz 0.6 dBmV 37.7 dB 0 0 4 Locked QAM256 15 591000000 Hz 0.8 dBmV 38 dB 0 0 5 Locked QAM256 16 597000000 Hz 0.8 dBmV 38 dB 0 0 6 Locked QAM256 17 603000000 Hz 0.5 dBmV 37.7 dB 0 0 7 Locked QAM256 18 609000000 Hz 1 dBmV 38.2 dB 0 0 8 Locked QAM256 21 627000000 Hz 0.5 dBmV 37.9 dB 3 0 9 Locked QAM256 22 633000000 Hz 0.7 dBmV 38.1 dB 3 0 10 Locked QAM256 23 639000000 Hz 0.6 dBmV 37.9 dB 2 0 11 Locked QAM256 24 645000000 Hz 0.4 dBmV 37.8 dB 0 0 12 Locked QAM256 2 657000000 Hz 0 dBmV 37.4 dB 0 0 13 Locked QAM256 3 663000000 Hz 0.4 dBmV 37.7 dB 0 0 14 Locked QAM256 4 669000000 Hz 0.1 dBmV 37.4 dB 0 0 15 Locked QAM256 5 675000000 Hz 0.4 dBmV 37.1 dB 0 0 16 Locked QAM256 6 681000000 Hz 0.4 dBmV 37.6 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 3 5120 Ksym/sec 32000000 Hz 45 dBmV 2 Locked TDMA and ATDMA 1 2560 Ksym/sec 23000000 Hz 45 dBmV 3 Locked TDMA and ATDMA 2 2560 Ksym/sec 27000000 Hz 44.5 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 38500000 Hz 44.5 dBmV - FURRYe38Jul 01, 2022Guru - Experienced User
There we go. Way better. Monitor it for a few days.
