jgreenex
Jun 30, 2022Aspirant
CM500 Errors and latest Firmware
I consistently get the following errors. Typically they coincide with a brief connectivity outage. 2022-6-29, 06:39:07 Notice (6) TLV-11 - unrecognized OID;CM-MAC=10:0c:6b:6a:8b:18;CMTS-M...
Jun 30, 2022Guru - Experienced User
Well your on the lower fringes of the power being a bit too low. Would be good if the power could come up just a bit.
Hoping the removal of the splitter can help.
All those events posted can only be controlled by the ISP. The mode is just reporting what is happening.
You have a few correct and un-correctables. Ensure all connections and fittings are snugg.
Good quality RG6 coax cable is recommended.
jgreenex
Jul 01, 2022Aspirant
Removing the splitter had a definite impact on the power. I'm really hoping this resolves this issue. Time will tell!
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- FURRYe38Jul 01, 2022Guru - Experienced User
There we go. Way better. Monitor it for a few days.
