Ddan-X
May 17, 2021Follower
CM500 ethernet light blinking amber when connect the R612 wifi router
I change the wifi router to R6120, and CM500 ethernet light blinking amber, But if connnect the old wifi router, CM500 ethernet light is green. why I change my old wifi router, because it link speed ...
May 18, 2021Guru - Experienced User
the R6120 isn't a gigabit router. Its only a 10/100mbps devices.
if you read the cm500's manual, if the ethernet port is amber, it means it only has a 10/100mbps connection which would correspond to your router.
