AnnaStafford's avatar
AnnaStafford
CM500 Ethernet Port Issue
My modem and router were in an armoire and the internet kept dropping so I moved it out to avoid overheating. But after I did I noticed that the Ethernet link between the modem and router was no longer working. I reset the modem, tried different cables, tried cleaning them, looked for damage, and none of that worked. Still have no internet.
I’m getting really frustrated because I have no idea what the problem is.
  • plemans's avatar
    On the modem, does the ethernet light come on when a device is connected to it?
    If you direct connect a pc/laptop to the modem (power it off for 5 minutes, then connect the pc and boot it back up) connect to it?
    • AnnaStafford's avatar
      AnnaStafford
      I haven’t tried connecting it to the PC but every time it’s connected to our router, it just rapidly flashes amber. The router has a solid green light
      • FURRYe38's avatar
        Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
        What is the brand and model of the host wifi router connected to the modem?
        What happens when you connect a wired PC to the modem with out the router?
