Hawkeye1027
Dec 20, 2016Aspirant
CM500 Event Log warnings - should I be concerned?
I have been receiving these Event Log entries for the past few days, don't know if I should be concerned or not. Modem status is "Good", speeds are at/above my contract level. But the words "Warnin...
DarrenM
Dec 22, 2016Sr. NETGEAR Moderator
Hello Hawkeye1027
Nothing to big to worry about its just failing to connect to your ISP server sometimes if you are not having internet issues do not worry but you may need the ISP to check the lines if you are having problems.
DarrenM
