raymondjtoth
Feb 17, 2022Guide
cm500 help
isp whoi i have tell me call netgear netgear tell me to call isp i get runaroun i see on modem lofin page under event log this on 192.168.100.1 under vent logs i see lots of these 2022-2-17...
Feb 17, 2022Guru - Experienced User
It helps more if you have the complete logs and the cable connections page.
- raymondjtothFeb 17, 2022Guide
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 561000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 1 561000000 Hz -1.1 dBmV 37.1 dB 0 0 2 Locked QAM256 2 567000000 Hz -1.4 dBmV 38.9 dB 413 0 3 Locked QAM256 3 573000000 Hz -0.7 dBmV 39.3 dB 195 0 4 Locked QAM256 4 579000000 Hz -1.5 dBmV 36.1 dB 85 0 5 Locked QAM256 5 585000000 Hz -2.2 dBmV 37.4 dB 633 1336 6 Locked QAM256 6 591000000 Hz -0.8 dBmV 40.2 dB 0 0 7 Locked QAM256 9 609000000 Hz -1.1 dBmV 39.3 dB 38 0 8 Locked QAM256 10 615000000 Hz -1.5 dBmV 36.7 dB 3116 0 9 Locked QAM256 21 687000000 Hz -0.7 dBmV 39.5 dB 0 0 10 Locked QAM256 22 693000000 Hz -0.2 dBmV 40.9 dB 0 0 11 Locked QAM256 23 699000000 Hz 0.1 dBmV 41.7 dB 0 0 12 Locked QAM256 24 705000000 Hz 1.6 dBmV 42.2 dB 0 0 13 Locked QAM256 25 711000000 Hz 1 dBmV 40.3 dB 0 0 14 Locked QAM256 26 717000000 Hz 0.6 dBmV 37.5 dB 94 0 15 Locked QAM256 27 723000000 Hz 1.3 dBmV 40 dB 0 0 16 Locked QAM256 28 729000000 Hz 0.3 dBmV 40.2 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 24600000 Hz 50.8 dBmV 2 Locked ATDMA 1 2560 Ksym/sec 18000000 Hz 51 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 31000000 Hz 51 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 37400000 Hz 51 dBmV Extended Upstream Transmit Power Enable Extended Upstream Transmit Power
Current System Time:Thu Feb 17 20:30:12 2022
System Up Time:02:52:53
2022-2-17, 20:15:36 Warning (5) MDD message timeout;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-17, 17:37:56 Notice (6) TLV-11 - unrecognized OID;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:00:33 Notice (6) Honoring MDD; IP provisioning mode = IPv4 1970-1-1, 00:00:27 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:27 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2022-2-17, 17:29:11 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-17, 17:29:05 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-17, 17:28:59 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:00:26 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2022-2-17, 11:32:15 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-17, 11:32:14 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-17, 11:32:09 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-17, 11:07:35 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-16, 20:12:04 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-16, 19:09:25 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:00:28 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:28 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2022-2-15, 17:25:15 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 17:25:15 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 17:25:15 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 17:24:06 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 17:23:57 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 17:23:55 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 17:23:53 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 16:27:45 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 16:27:41 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:00:26 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:28 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2022-2-15, 16:01:34 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 16:01:18 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 16:01:13 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 15:58:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; 2022-2-15, 15:57:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; - plemansFeb 17, 2022Guru - Experienced User
Your logs are indicating line issues.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
