Joepence
Oct 05, 2022Follower
cm500 how to switch to 2.4ghz
how can I get into settings to change network to 2.4ghz? I have some lights that are wifi enabled and 2 of the 4 keep losing signal. I thought maybe I could try to make sure they are on the right c...
Sewmsata
Oct 05, 2022Aspirant
Click advanced setup then customize wifi network. In the customize your wifi- create a separate 2.4GHz wifi network section after that select customize 2.4 GHz wifi network. Enter a network name (SSID) for your 2.4GHz network.
Joepence myLoyola Login wrote:how can I get into settings to change network to 2.4ghz? I have some lights that are wifi enabled and 2 of the 4 keep losing signal. I thought maybe I could try to make sure they are on the right channel.
