Joepence
Oct 05, 2022Follower
cm500 how to switch to 2.4ghz
how can I get into settings to change network to 2.4ghz? I have some lights that are wifi enabled and 2 of the 4 keep losing signal. I thought maybe I could try to make sure they are on the right c...
Oct 06, 2022Guru - Experienced User
The CM500 is a modem only device. It has no wireless functions.
so there isn't anything to change on it.
What actual router do you have?
