silver123
Jul 19, 2016Aspirant
CM500 intermittent brief connection issues TWC
My cable modem is dropping internet connectivity recently for a few seconds then reconnects. My neighbors recently installed ATT on each side of my house and I know ATT was inside the box that's in ...
DarrenM
Jul 21, 2016Sr. NETGEAR Moderator
Hello silver123
I see alot of T3 and T4 timeouts I would say there is a signal issue going on with TWC they may of messed with some cable lines when installing stuff at your neighbors home. I would have TWC send a tech out to check the lines in your place and out at the pole.
DarrenM
- silver123Jul 21, 2016Aspirant
Thanks, I pretty much figured, which thank GOD when I called them yesterday the tech was inside the US so English wasn't a problem, they're sending out someone Saturday......zero issues today HA so after 4 days of problems the day after I call it resolves itself, but I'm going to have them double check everything anyways.
I don't get my 300 down as advertised, which I suspect is because I have an OOMA (VOIP) box on the line and that seems to suck up a massive amount of my bandwith
